Stock Weight...
My 86 951 with sunroof and all the standard stock equipment with 1/4 tank of gas, spare, and heavy briefcase and 186 lb driver weighed 3109 lbs on a certified truck weigh scale. That would put the car in at approx 2900lbs without driver.
Originally posted by M758
I had my Turbo S corner balanced.
3320 with my 170 lbs weight in it. Included was 1/2 tank of gas. Standard spare tire & tool kit. Extras where supplemental tool kit of sockets and wrenches. 2 qts oil and 1 gallon of water.
Sounds familiar. I had a bit more gas in my car than you, which makes up for the tools/oil/water you had in your car.
Curb weight is what your car weighs when it's parked at the kerb. So you'll have your spare-tire and tool-kit in there. All fluids like oil & coolant topped off. But only 1/2 tank of gas because that's the average of all the times you park at the kerb. Some times, you'll have a full tank. Other time, you'll be empty.
My '86 951 after corner-balancing came out to 2910-lbs with spare-tire removed and interior behind rearr seats removed. But I added some back with roll-bar.
Drive-by provocation guy
COOL!!
Went with a friend today to the county dump and they have the drive up scale. I asked them about it's accuracy and they said it is pretty close. I will go down this week and get mine weighed.
I drove into my -86 into corner weights previously with 200 lbs driver, standard tools and spare tire and ended up 3200.
51.6 % weight on front
cross weights 50/50
I am pretty happy with result.
hrk
cross weights 50/50
hrk
I would hope to be 2800 with everything I've had done to it. I say 2900 as I have never weighed it. Lightened flywheel, 16 lbs. lighter motor than stock, header and exhaust, no spare tire or jack, Kenisis wheels 21lbs a piece.
Stock 1989 with spare, usual stuff in car and half tank of gas was 3080 without driver. A few less options than the Turbo S perhaps? I think a good weight for the non-S, non ABS 1988 would be around 3050 pounds plus driver.
Monkeys Removed by Request
i weighed mine at the track....it weighed 3047......with about 3/4 tank of gas...spare tire....full interior...ect.ect.I was pretty happy with that number...athough thats without my cheeseburger eating butt in the seat!
