Running temperature
So, November is here and the first frosty morning of the year today. I've been noticing that my "on the move" running temps seem quite low recently. I pulled the thermostat and its an 87deg version. It had been installed without the o-ring so I replaced it with a spare. It now runs a tad bit warmer but still under the first indicator mark (80deg).
Any idea why it should be running cool like this? What are you guys seeing on your gauges?
I swapped in another intrument cluster and the temps are the same so I doubt it's a bad gauge. The fans kick in just after it passes the first mark, again, seems too low compared with other 944's I've had. I'll pull the sender and check the wiring next but what is considered "normal" gauge readings in terms of cruising and fan operation?
My car normally runs right at or just below the first line, even at the track.
I do run E85 which helps to keep everything cooler.
Always just above the 80c mark, Summer and Winter. At consecutive long Stop Lights it may go to half for 30 seconds as the Fans wail. Very happy that it puts out real interior heat in 30 seconds from cold start up too. That wasn't always the case till I had the Radiator out and pro flushed after seeing what was in the Oil Cooler, ... scary stuff from 25 years of use. Too cold is not a usual problem, you may still have a Thermostat issue.
After I had the WP replaced by a shop (I was stuck in CA on a 50/50 work/vacation trip) my car sits directly on, or juuuust above the first white line. According to my external water temp gauge (probe installed in the neck on the head, so pretty much the hottest point) it sits right around 195.
Thanks for your replies and suggestions guys.
It was a cheap thermostat afterall. I replaced it with a Wahler and its back close to the 80deg first mark and getting up to temp much quicker too.
