Temp guage question
8th Gear
Temp guage question
When driving the temp guage flucuates, from just below the first line to just below the second line, never overheats but jumps up and down.
Any thoughts? Something I should worry about?
Thanks for the help.
If it's actually jumping (like bouncing) around, then it may be a bad ground... fairly common problem. Do a search of this forum on "ground" to locate all the grouding points (there are a bunch) and clean them up... (Main one for instruments is under the dash on the driver side above the hood release.)
There's also a tech proceedure on the Paragon website (I think) that details how to clean up the grounds inside the instrument cluster.
Finally, if you want the ultimate ground solutions, take a look at the wiring kits from "IceShark" (fellow Rennlister) at the "Guru" web site (www.gururacing.net I think). Really nice stuff.
