tial 38 to Ebc
Ok will try that...is it possible it will click and still be faulty , any one have proper diagram... I'm going to install a manual controller ... Will see if its the ebc or not
Nope. When I was going through trying to work out what was wrong with my set up(jnr mechnic who was sacked shortly afterwards, had put WG on backwards) the guys at turbo smart were saying they virtually never go bad, and as long as it clicks, its good.
If I had the wg on backwords will I still get spring pressure? When I have it hooked up with out the controller I get 1 bar of boost and I have a 1 bar spring... So it must be installed right way correct
Correct in that you would over boost not see spring pressure. When I bypassed my EBC by going single port, mine was still over boosting, when like you, I should have seen spring pressure which is what led me to suss out my WG was incorrectly installed
Ok had the lines right still not working .. took a power probe to the solenoid it has ground and power... But when I give it power I do not hear a click so I take it I need a new one
