specalized ecu repair
1 Post
Hello. I had me dme and klr rebuilt by specalized ecu repair in Florida ($700). I'm having issues with a misfire after driving for a while or in high load conditions. It did not do this before the new/rebuilt ecu and I can't seem to get them to do anything to prove it is not the ecu. I have replaced all of the ignition parts trying to chase this down. Any recommendations on how to get them to fix it? I think it is an inferior ignition transistor that overheats and fails.
1 Post
They have been reluctant to accept that the ecu could be the problem. This despite the fact that the problem was not there before the ecu died and I have replaced any potential problem components.
1 Post
I don't have a way to log the actual output of the ignition signal to the coil which is what a suspect is the failure.
I did try another DME when mine died but that one was dead too...It seems that all of my 944 friends that could have loaned me a DME have moved away back to California or to the east coast.
I spoke to the ECU repair guys today and they think it is some other problem like a vacuum leak. this is not impossible but is unlikely given the engine rebuild I did 8k miles ago and the failure mode of the misfire.
