Turn signal Buzzer installation info
My turn signal no more switch off when i rotate the steering wheel, due to a problem with the steering column switch.
So i'd like to install a buzzer for remember me to switch off the turn signal.
How can i wire it?
The blinker in the central electric inside the engine bay has 4 pins: 31-49-49a-C2.
31 is 12V
C2 is the hazard signal
The pins 49 and 49a have an intermittent 12v when i switch on the turn signal, but have about 5v with turn signal switched off, too with the flasher disconnected. So with turn signal on the buzzer is ok, but with turn signal off the buzzer is Always on....
How can i solve?
How can i wire it?
31 is 12V
How can i solve?
