16v head cfm numbers
#106
With reference to the flow chart above, I had the opportunity to flow test both a 951 2V head and a 944NA 2V head after they were prepped, and the flow numbers were virtually the same. Bone stock heads vary on the flow bench - usually due to the valve job (either worn or not performance oriented).
