rogue data logger help
I shot Josh an email about this, but given what all he has going on, I figured I'd ask on here as well.
Finally got some time to install my mtune data logger. Already have the tuner working, so I had tunerpro rt installed..etc.
I wired up the logger to the 2 dme wires (ground and serial), and my pc saw and installed a driver for the logger. but when I try to connect (after setting the com port), tuner pro just says "da connecting" and never connects.
not sure what all I can try at this point, but figured someone might have an idea.
Try different serial ports - pretty much what I think Shawn was referring to.
I got mine working on my tablet w/Win 8.1 (woo-boo!) - I had the wrong COM port selected in TunerPro.
With some help from josh I got it working. Thanks josh!! For some reason my old dme (non tuner) would not send serial data but my tuner enabled dme (which I need to use anyways) worked fine
How do I add items to log? I want to log the sensors. Etc. I see them in the list but not in th graph mode
