Im back with a 944 turbo s
Just picked my car up from TKX with just everything on the front replaced , timing belt, water pump, balance belt, all bearings and seals, they found a broken vacuum line and flushed the braking system even got a PCA tech inspection done and now she has a clean bill of health. Was supposed to be at the track today but got very sick yesterday could not even walk. What a bummer, next event NJMP is September..
I did talk to Thom about your install when the winter comes that is the way i will go, did you sell your turbo motor and recoupe any of your budget how hard was it to sell the turbo motor?? Give me a call when you get a chance 631 504-1440 i would love to come check out you build and pick your brains..Thanks Barry
From a member here its the GT Racing version not easy to install no hardware no holes drilled , and it also needs trimming to fit but after all that im very happy with it..
Car looks great
Would you like to add it to the 944 Turbo S Register that has been set up? If so would be good to have another car added. The link is below
www.944silverrose.co.uk
Cheers
Martin
Cheers
Martin
