brake caliper slide plates
I am just starting a caliper rebuild/refinish and I wanted to get the steel plates off. I don't think I really need to - I just wanted to be thorough, but I can't get the little torx screws out. Following a suggestion from Olli in another thread I put the caliper in citric acid for a few hours, which did a great job of cleaning it. Then I got an electric heat gun and heated the screw for quite a while. Still no luck. I tried hitting it with a chisel to rotate it...all that does it chip away at the head and soon there will be nothing left if I keep doing that.
At this point there are still a few things I haven't tried - like cutting a slot for a screwdriver, but I'm not too hopeful. Welding is not an option for me. I thought I might file 2 flat sections at opposite sides and grab it with a channel locks. I'm looking for opinions - my options seem to be either carry on with the rebuild and forget about the steel plates, or take them to a machine shop. What would you do? They don't seem to be having any corrosion issues, but I hate doing anything half baked.
At this point mig welding machine is your friend. I use it all the time when rebuilding calipers. Just weld a bolt to that caliper bolt and turn them away. I usually use 13mm head bolts to do the job. If you plan to re-use dust shields, remove them before welding.
Update...I took one of them to a machine shop and they agreed welding on a nut is probably the only way. They quoted $40 per caliper. That's not too bad but with the extra hassle and the risk of them damaging something, I think I will just leave well enough alone.
