Lindsey Racing BOV Spring
Hey Guys,
Should I run the stock or stiff spring?
89 951
M Tune😄
E85
K27/8
18-19 psi
89 951
M Tune😄
E85
K27/8
18-19 psi
Should have said I am installing LR's billet BOV.
Which one would you start with?
Professional Hoon
light.
then put the stiffer one in.
if you have the capabilities to log boost and rpm, do it.
if you can feel a difference between the stiff one and the softer one like less response of the turbo, keep the stiff one in.
If you hear a flutter noise (sut sut sut sut sut noise) put the softer one back on.
