Rust in fuel rail?
Rust in fuel rail?
After receiving my grounding kit from Robby, I decided its time to finally pull off my manifold for the 1st time. I've owned this car for around 7 years and have about 1000 miles on it. It hasn't ever run totally right and I'm making a push to get it fully functional for the summer.
I decided to pull the manifold to make the negative cable easier to install, and to do the fuel/vacuum lines and have the injectors balanced and cleaned.
Pulled the rail off and found that when drained I got fuel with some rust particles in it. (poured out onto my white paper towel) So after pulling the injectors, I can see that the inside of the rail is coated with surface rust. Has anyone else seen this problem? Any suggestions for cleaning it up, or should I replace the rail? (if so, anyone have a clean one, please pm me) Should I worry that the FPR and or Damper could be damaged or full of garbage?
Regardless of what I do, I would like to purge the system with fuel BEFORE I put my balanced injectors back in. Suggestions on doing that?
Lots of questions, hopefully someone has seen and dealt with this before. :-) Thanks!
Replace the rail.
Drain the tank and pull the fuel screen to clean it.
Replace the filter.
Buy fuel, put a few gallons in the tank. Pull off the fuel pressure testing cap, hook up a hose to it, and bridge the fuel pump relay. Purge at least a gallon or so.
Old fuel is bad news, if the car is going to be in storage for more than 6 months, drain the tank.
Replace the filter.
I guess I'll look for a clean rail and will certainly do the purge you describe! Anyone have a clean rail? :-) Is it the same between NA and turbo? Looks like it is based on the parts catalog.
Replacement fuel rail inbound, injectors at Witchhunter currently. Hopefully it'll run well next week and I can actually drive it to Hershey. :-) I want it to run 100% right STOCK before I start with the A-Tune and MBC, etc..
