Vitesse MAF Connector wiring
Hopefully one of you guys can help me out here, the wiring for the MAF connector managed to get caught in the headlight mechanism and pulled from the MAF connector.
What I need is someone who is running the 6 wire MAF to check what color wire goes to what pin. For some unknown reason, all the wires in the MAF pigtail are GRAY!
I contacted John, and sent the requested pictures and chipboard serial number, but from talking with him, I have the felling it is going to take a few days to get the information.
What I need is someone to check the MAF CONNECTOR and tell me what color wire goes where.....I know Pin 2 is the POWER, because that wire was separate from the harness and did not pull out......So, anyone care to look at their connector and tell me the following?
Pin 1, what color wire?
Pin 2, POWER
Pin 3, what color wire?
Pin 4, what color wire?
Pin 5, what color wire?
Pin 6, what color wire?
Pin 2, POWER
John @ Vitesse sent me a set of instructions so that I can rewire the MAF connector.
John just called to make sure I had received the instructions and pass on a few more tips to make life easier.
Thanks for the fast response, instructions and follow up call John!
