Winter storage
Winter storage
Hi, I was in a hurry when I stored my car this fall and didn't fill the fuel tank full and didn't add fuel stabilizer. My tank is at 3/4, what do you suggest me to do ? The car was in a non-heated garage and the winter was very cold this year.
I had to replace injectors seals this winter so the fuel rail is empty right now.
The ~60 degree bent piece of rubber tubing between the fuel tank strainer and the fuel pump makes for a great way to dump the tank into containers. To cut off the flow clamp the line. Alternatively some people will unhook the intake line to the fuel rail and empty it into a container with the fuel pump. I prefer the former method. Either way, dump that gas. You'll now have several years worth gas for your lawn mower.
