Does the windage tray complicate rod bearing servicing?
Do you have to undo the main fasteners in the crank case and risk breaking the loctite 574 seal to service the rod bearings once a windage tray has been installed?
I don't have one, I have the scrapers. I'm considering one, or building one for the scrapers I have.
By the way, how is the teflon blade mounted to the scraper is it sandwiched between 2 or 3 metal blades?
I don't understand the purpose of this kind of windage tray on 944.
Why would it need to be here?
