horn
horn
87 944 turbo, one horn faces down and the other faces forward. Does anyone know which horn is the low pitch and which one is the high pitch? I removed the alternator plastic vent pipe finally after doing my nissan alt mod. after removing the pipe the low pitch horn doesnt seem to be sounding, only the high is working. Im guessing something came loose when removing the pipe. im trying to not honk the horn as much as possible, neighbors probably wont like that lol
Regards
Ed
PS I think I remember the wires having rubber boost on them ??
i already checked the relay, fuse, and all 4 connection points on the horns. i believe one of the horns was damaged when removing the alt duct. i suspect the low horn because my horn now sounds like hermie lol no low end tone. they are easily accessable being that i dont use the factory batwing and i have the alt duct removed with my nissan alt mod. ill probably try to bench test them later tomorrow
