DIY Fuel System Project
I can tell you that trying to describe these pieces to a "counter guy" at some of these hydraulic shops may come across like you're speaking chinese. The moment you mention metric, they may loose interest in your business pretty fast. So, having the specific part numbers will get you through any potential confusion!
You'll need a hydraulic shop to crimp a 1/4 NPT fitting to the hose and you'll need a female / female coupling to connect the fuel pressure "peanut" gauge to the coupling.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I didn't see the color comment, mine extra one is red. Nothing that your bead blaster, self etching primer, and black engine enamel won't cure. Don't think powder coating necessary, it is just a cover. I agree with Vic on the good clamps. That bad *** Scandinavian aircraft clamp works perfectly.
Amazing information! Thanks for posting!
Couple of NOOB questions:
Since the 2 hard lines are different sizes and the factory rubber lines are sized differently, doesn't it stand to reason that the end at the damper and FPR are different sizes? You show the lines as being 8mm for the return and 10mm for the feed. 8mm equates to a -5AN standard clamp connection at the FPR, and this is showing a -6AN works fine? I've not measured the nipple yet, but I'd guess 2mm difference is significant!
On the clamp end, do you treat the loose metal or plastic braiding any way before putting the clamp on? Tape, heat shrink, etc..?
Here is a link to Eaton/Aeroquip literature (PDF) that has info on assembly of hoses starting on page 44; also it contains some useful info on how to properly run the hoses.
http://www.eaton.com/ecm/groups/publ...pct_369349.pdf
I have installed hydraulic hoses on household plumbing to nuclear reactor components and have been trained by Aeroquip on hoses/fittings and proper installation; a few things to look for on installation are: the hoses and fittings do not touch adjoining lines and have a proper bracket to separate them and do not exceed the bend radius of the hose (hose bends should start 1 1/2 x the diameter of the hose past the end of the fitting); both those are noted in the literature.
Defending the Border
Rest In Peace
Rest In Peace
I remember building my set, a bit of a pain but a hell of a lot more enjoyable than dealing with an engine fire.
I hate those guys at BAT, they damn near have the market cornered... argh.
I got "confused" trying to figure out the fittings for the fuel damper?? But PN's and pictures work for me!
"BAT" pdf ... problem solved! Thanks!
http://www.batinc.net/files/ahosend.pdf
