Need some help on pressurizing system
Less than 10 psi when I'm testing it. Thing is i should be getting 15 lbs of boost but I'm not quite hitting my target, that's why I was pressure testing the system
Well you have to remember your putting pressure in it while testing, the aos doesn't see boost, just vacuum. So it's very possible it's not even leaking under vacuum. Even if it is leaking I don't think it's going to cause you not to reach proper boost levels but more so throw off your afr.
Okay now I've run into a bigger problem. It seems that there is air coming out from the gasket at the cam cover in one small spot. It looks like I will have to either remove the cam cover and replace the gasket the right way, for as bad as this sounds maybe there's a way I can put sealant in the gap. Taking the cam cover off as a whole but the bit of misery I don't want to have to get into the front belt again.
I'm assuming pressurized air coming out of the cam cover gasket is not a good thing.
Okay now I've run into a bigger problem. It seems that there is air coming out from the gasket at the cam cover in one small spot. It looks like I will have to either remove the cam cover and replace the gasket the right way, for as bad as this sounds maybe there's a way I can put sealant in the gap. Taking the cam cover off as a whole but the bit of misery I don't want to have to get into the front belt again. I'm assuming pressurized air coming out of the cam cover gasket is not a good thing.
I'm in Louisiana. There is definitely a leak coming out of the gasket I just pulled the fuel rail and you could put your finger right over the edge and gasket and stop The air from coming out.
Okay so I've taken a video of the system under pressure it's under 11 1/2 PSI and the sound you hear is mostly what seems to be the air oil separator O-rings pushing air out seems a lot to me. However in this video I'm showing you the leak at the cam tower check the link below.
Okay so I've taken a video of the system under pressure it's under 11 1/2 PSI and the sound you hear is mostly what seems to be the air oil separator O-rings pushing air out seems a lot to me. However in this video I'm showing you the leak at the cam tower check the link below. Video Link: http://www.youtube.com/watch?v=lQsSy4AilJ8
That leak isn't going to affect your actual boost, it seems odd that you have enough pressure in your crankcase to blow the o ring and your cam tower gasket tho, you don't by chance have your hoses crossed and have your aos running off your intercooler pipe do you?
Could it be that a valve was open and air is getting around thus causing an air leak.
I just had a leak down done everything was fine.
How much pressure what I have to put in the engine damage the rings on the piston to do this?
Also I do have to fix this right, or oil start coming up that whole am assuming?
I don't think I have anything crossed. I have not actually changed any of those hoses myself.
By intercooler pipe do you mean the hard pipe to the left of the air filter?
I don't have a clue what that first sentence says......
