oil cooler
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Will AN fittings work with it? Curious I did noticed there are adapters on each end so my question is are the thread pitch by chance any AN pitch??
Costas
Costas
Van is correct, it's M22. You can get M22 to -12AN adapters for about $10/ea. However, the hard pipe to soft line connectors are M26 which is very difficult to find and IIRC the M26/-12AN adapters were $35+/ea. Whatcha got planned?
The Lindsey Cooler does that, 22 to 12AN. I personally made a similar setup at half the cost using the FD RX-7 oil cooler. 2 fitting adapters, 4 aeroquip fittings with braided hose lines, 2 12AN fittings to weld onto the cooler, and the cooler itself.
Thanks Aaron ...I am not sure what I am up to yet just getting ideas. Also a great idea there doabarrelroll!
I do know I will be creating something for my car cheaper then the off the shelf options.
Thats a great site looks like i will be going in a different direction already. Are there prices good?? MJ951?
Freedom Enthusiast
Yeah, BAT has a lot if metric fittings that you can't get otherwise. They are good people, too.
However, I think you can also get the M22 to -AN12 adapter from summit.
FYI, those are the same adapters you need for the oil filter console, too.
I never compared pricing but sourced all my coolers, lines, fittings and adapters from them. Great site, products came as ordered, no issues. Will use them again.
