How much power gain from wastegate shim?
saying power gain I meant more boost that produced extra hp. correct me if I'm wrong here. on 3rd and 4th and pedal fully depressed boost gauge (stock) goes all the way to 2 bar mark or just below, like 1.95 I know it is inaccurate but on the other hand when I had system in safe mode for some time it stopped at 1.2 bar sharp, just as expected, so there is some accuracy in the gauge, at least in lower levels I think
Decking the head to the max means 0.02", or 0.5mm. Should be good for almost half a point gain in compression. I'm also pretty sure that a 1.4mm thick head gasket is stock as well. I dont think you picked up 25hp here...
Long story short, 300whp is agreed to be the about most you can pull out of a k26/8 turbo.
