Fuel Transfusion
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
After a chat with Shawn tonight, he gave me a great idea that honestly I had never thought of. It worked so easily and great that I am going to post this up for some of the young guys or anybody that has not thought of this before. I needed to empty all of the gas from my gas tank in order to exchange with E-85. I am going for emissions this weekend and don't want a mixture but there are many reasons for needing to drain the tank such as a fuel pump replacement. Anyway so not much to the procedure: Disconnect fuel line to regulator. Attach a long length of hose to regulator and insert into gas can or into one of your other cars. Remove DME relay Jump 30, 87, & 87B You will here it when it is done, noise from fuel pump increases dramatically.
![Name: image-3704387078.jpg
Size: 436.3 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/774464d1383193489-fuel-transfusion-image-3704387078.jpg)
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Frist of all - that's the fuel pressure regulator not the damper.
If you took the input line to the damper you would get more fuel flow.
All the rest is good!
1 Post
Chris: Thanks! That's what I get posting at midnight after a 14 hour day at work! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I meant to use that line, but could not find an adaptor. This way worked and was simpler on my car as it was just a hose clamp.
