Representing the Marque and 951!
Old 10-27-2013, 09:07 PM
  #61
blitz951
blitz951's Avatar
Great work patrick, i cant say enough. Tony's done a great job but his car is not a 944 or even a porsche at this point so you cant compare. You took the 951 and showed us what it can do.
Old 10-28-2013, 09:14 PM
  #62
333pg333
333pg333's Avatar
Thanks RB. It's a great feeling to have the car producing such good results in such a short time. Can't wait to get back out onto the track to continue my 'education' with the new car.
Side effect: My neck has been hurting this week and I'm sure it's to do with all the extra grip the car is producing!
Old 10-29-2013, 12:46 AM
  #63
Dubai944
Dubai944's Avatar
What are the current tyre sizes you are using?
Old 10-29-2013, 03:06 AM
  #64
333pg333
333pg333's Avatar
295/30 x 18" Yoko AO50's all round Steve. Been a while since I've done any driving but I'm impressed with these so far. Softs are very sticky but you don't get a lot of laps out of them.
Old 10-29-2013, 04:21 AM
  #65
Dubai944
Dubai944's Avatar
Sounds like a good tyre. Pity that's the largest size available.
Old 10-29-2013, 07:08 PM
  #66
333pg333
333pg333's Avatar
I'm really curious how these compare to slicks. I think the slick must still be more stable with the stiffer sidewalls but I'm not sure how much difference there will be in the times? Also the R specs get to heat much quicker I suspect...but, at what cost. If you want to run the Soft compound in the R spec I would say you can get very good times but with a very limited duration for each heat cycle and quite possibly fewer useable heat cycles overall. I will be trying slicks next season. Not sure on compound comparison on slicks, nor how many heat cycles one gets out of their softer compounds?
Old 10-29-2013, 09:35 PM
  #67
Eric_k
Eric_k's Avatar
That's one mean car you have Patrick.
I used slicks (Hoosier R80) for the first time last week and they had a lot more grip than the Hankook Z214 c51 that I used right after them. No idea how long the slicks last but they did a 2 hour stint on my car no problem. I suspect heat cycles would get them before running out of rubber.
Old 10-29-2013, 10:54 PM
  #68
333pg333
333pg333's Avatar
Thanks Eric. I've run the R80's before and thought they were pretty good but it wasn't really for long enough to form an educated opinion. Might try them again but I've also heard a few issues surrounding Hoosiers on the Racing forums?
Old 10-30-2013, 08:44 AM
  #69
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Hi Patrick - nice work out there! Annoying cup cars is one of the finer things in life, they usually just come over to the garage and stare at the car from 50'!
You will like the GTX turbo - very similar to the one I posted graphs on a little while ago, I am looking forward to comparing your charts when you get it dynoed. should be 1 bar at 3600-3700 rpm.
Old 10-30-2013, 03:37 PM
  #70
333pg333
333pg333's Avatar
Thanks Chris. This one definitely 'feels' like it's coming on in a more contemporary nature. The previous on was fun but just a bit harder to drive out of corners with the lag/bang aspect. I actually need to stop spending for now which fortunately coincides with the season coming to a close...even though I'd like to be out there most weekends having just 'unwrapped' the car. Re grouping sounds sensible though.
Old 11-08-2013, 11:16 PM
  #71
hally
hally's Avatar
Originally Posted by Voith
Bam and its gone.
Great to see u have it back on the track Patrick
Old 11-11-2013, 11:31 AM
  #72
disasterman
disasterman's Avatar
Patrick,
Long road back but now you get to enjoy it. How about posting some photos of your body build. I am about to "get wide" and working out some of the details. Expect to run a square setup of 295/30/18's as well and curious about how your wheels are set up, spacer etc.
Regards
Old 11-12-2013, 06:37 AM
  #73
Raceboy
Raceboy's Avatar
Originally Posted by disasterman
Patrick,
Regards
If someone is interested, I have a set of very nice Speedline Corse Magnesium wheels. They are 10x18 (ET24) and 11x18 (ET15), weights are 7,1 kg and 7,9 kg respectively. They are perfect for going wider without any need for spacers etc. Wheels are brand new, just been sitting under a project car for a while.
Sry for OT.
Quick Reply: Representing the Marque and 951!
