cv stage 8 lockers
Installing the cv's with stage 8 locker hardware. They appear to be a bit longer than stock cv bolts and work on trans side but bottom out on wheel side where wheel does not turn when torqued. Is 8mm-1.25x50mm the right size for a 951? Part #8324.
Attachment 771192
Attachment 771192
Went with new stock bolts on the wheel side and stage 8 on the trans stubs. Might just use as spares. For some reason stock cv bolts just unwind at pass side trans stub, problem solved for now.
