Strange OPRV
I was looking at some OPRV threads today, and found out that my oprv is different than both early and late..
Is this third option or this some other valve I confused with OPRV?
Oil Pressure Relief Valve
The idea is that oil does not exceed certain pressure, since pump is RPM dependent..
As far as I remember there is, but I don't find it at the moment.. I took the engine apart few years ago and yesterday I was arranging all back together and I foud this protected in styrofoam.. If I remember correctly I put the oprv in styrofoam, so this should be it..
It definitely came off my 951.
There is a very short threaded bolt (more like a cap) on the housing that covers the hole/cylinder containing the OPRV - the OPRV pushes against this cap. In my car, I have the 3-piece OPRV with a spring that simply provides the force within the OPRV in the cylinder. The OPRV in the pic above is a copy of a newer version, and I don't know exactly how that works.
alex I think you nailed it. Thanks!
I must have packed the oil housing oprv somewhere else..
Basic Sponsor
Yes, some simple measuring will confirm is the pressure valve on the head, I believe the picture made it appear larger than it is.
