just dyno'ed my 89 951
Old 11-15-2013, 08:11 PM
  #61
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Glad to hear your getting the car sorted... Another way of thinking about it - every boost leak is an energy leak, it is your best interest to eliminate all boost leaks possible.
Old 11-15-2013, 08:59 PM
  #62
Carlsbergas
Carlsbergas's Avatar
Yeah that diverter valve leak was messing up with my spool time and boost
I think my last dino while still having welt chips had same boost leak, o well i hoping to see some big numbers next time im hitting dyno
Old 11-19-2013, 04:49 PM
  #63
Carlsbergas
Dont mind the 2nd and 3rd run afr ratio, exhaust came of. im not impressed with the numbers tho, gonna need to check my injector flow, and i have no idea why numbers are low like this, dyno was a mustang btw they say it always reads a llitle bit lower than other dyno
And here is my old dyno run with welt chips
Old 11-19-2013, 09:38 PM
  #64
Carlsbergas
One intresting note first run they did they hadnt turned on 4wd dyno only my back wheels were spining so result was 450whp after that they did 3 runs where my front and back wheels were turning
Old 11-20-2013, 12:21 AM
  #65
onspeed
onspeed's Avatar
What? Why would you need front wheels spinning for a rear wheel drive car?
Also, your AFR is still too rich.
Old 11-20-2013, 02:06 AM
  #66
Carlsbergas
I dont know, thats their setup for new cars with traction controls.. what should be optimal afr?
Old 11-20-2013, 02:18 AM
  #67
333pg333
333pg333's Avatar
Errr....huh???
Old 11-20-2013, 02:30 AM
  #68
Carlsbergas
They connect back dyno rollers to the front ones so when my rear wheels start to spin it makes front rollers start spinning too
Old 11-20-2013, 04:31 AM
  #69
333pg333
333pg333's Avatar
Hmm...that sounds weird. If your rear wheels are in effect driving the front ones you'd be suffering a heap of parasitic loss. Also, from what I can see, your car registered about 240whp. Where is the 450whp?
Old 11-20-2013, 05:14 AM
  #70
Reimu
Reimu's Avatar
I'm confused
Old 11-20-2013, 08:16 AM
  #71
mtnman82
mtnman82's Avatar
Originally Posted by Reimu
I'm confused
+1
I've seen tons of pic's on here with the front wheels strapped down on the dyno.
Bur with your setup 240whp with an issue or two to fix seems a lot more realistic than 450whp.
Old 11-20-2013, 08:38 AM
  #72
Carlsbergas
They didnt save that run because it was so inaccurate.. im giving up on runing rich solution.. i hope injector flow matching and cleaning will help even out the jaggedeness in power and torque
Old 11-20-2013, 10:09 AM
  #73
Carlsbergas
Then again i always forget that i have 2degree timing advance wich should drop my top end power and get me low end
Old 11-20-2013, 10:45 AM
  #74
User 52121
User 52121's Avatar
You probably still have a boost leak or 3.
Old 11-20-2013, 04:51 PM
  #75
odb812
odb812's Avatar
I agree. OP, your AFR going very rich at the same point on the graph where you're hitting full boost is a pretty good sign of a boost leak.
To touch on a more basic point, you are going to spend a ton of money getting your car in order the way you are approaching it now. Unless it's free, hold off on the dyno time until you know you've sorted out all of your issues. Pick up a wideband O2 sensor and aftermarket boost gauge if you haven't already and spend some time on here reading about how to use them. Then proceed with the dyno runs and go fast stuff after you see the car is running properly.
Quick Reply: just dyno'ed my 89 951
