rear suspension setup question
86 951, bilstein cup suspension (progressive helper spring and stock torsion bars), stock rubber mounts on torsion bar carrier and sphericals and metal bushings on the swing arms.
tires are 335/30-18 on 13 inch rims.
Camber? factory for 86 is -25 +/- 30' and -1 degree +/- 30' for US
Toe? factory for 86 is 0' +/- 5'
The settings for >90 are slightly different. WHat changed at the back of the car?
The intended use is street/track. I'm a track weenie, a nice stable feel is what I'm after. I tried positive toe at the front and didn't like it.
Regards,
doug
86 951 (http://pcaucr.org/media/image-galler...ll&gallery=224)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
OK, I'm bumping this thread because I could use some input from the "gently modified" crowd before I actually dollars for an alignment. Pix here.
The specs are:
11x18 285/30F
13x18 335/30R
Michelin pilot sport street tires
full Cup suspension, progressive springs, shocks and sway bars (30 mm Tubular F 24mm R) and stock 23.5 mm torsion bars.
Fabcar control arms Delrin front and 968 rear bushing
swingarms are elephant monoballs and bushings, but stock rubber mounts for the torsion bar carrier.
Questions:
for a street/track set up is 1.5 degrees front camber OK? I used to have 1.75 degrees back when I 255/40 and 275/40-17s.
Zero front toe?
I had a problem trying to max front caster. I got binding in the bushings, so I baked off till it moved freely.
any suggestions for the rear?
Also, am I better off with a Hunter alignment machine at a generic repair place, or a local race shop with a collection of alignment plates? Comments?Regards,
doug
83 944 (sold in 86)
The specs are:
11x18 285/30F
13x18 335/30R
Questions:
Zero front toe?
doug
83 944 (sold in 86)
Is that the same Van on this list with the Dragon biting porsche avatar?
You mean this:
http://www.smartracingproducts.com/smartstrings.html
Regards,
doug
83 944 (sold in 86)
You mean this:
Regards,
doug
83 944 (sold in 86)
Or mebbe this?
http://www.advantagewheelalignment.com/Lazer_Align.html
Now thats something I could fake. I didn't spend 8 years as a gradual student at the University of Rochester's Laboratory For Laser Energetics (Laser Lab) for nuthin. Time to gather the minions...
Regards,
doug
83 944 (sold in 86)
Regards,
doug
83 944 (sold in 86)
