Turbo waterpump relay
Hey Guys, I was poking around under the hood today and noticed that my Turbo Water Pump relay was missing. Is this bad? I eventually found it in a box of parts from the mechanic and after plugging it back in I see why it was removed. Once the car is shut off the pump doesn't stop. Has anyone had a problem like this? is there an easy fix or do I just need a new relay?
Actually, 2 days ago I did take the relay apart, cleaned all the crud (technical term) I could find and when I put it back everything worked perfectly. I have started and shut off the car about 12 times since then and each time it worked flawlessly.
