Turbo Coolant Pump making Noise
hello,
my turbo coolant pump is all of a sudden making shrieking, whining noises and just wondering if this means imminent failure or if there are any things i can do to restore it. it basically is making the consistent shrieking noise whenever the pump is running.
any thoughts or info about a fix (other than replacing) or other musings of turbo pump knowledge????
many thanks and i did a search but didn't find anything about noises from the pump so maybe my car is special.
My pump made noise for a long time, but was definitely pumping coolant, so I let it go for a while. I replaced it with a good used pump and have been fine ever since, so maybe these failures aren't very common. It was a bit of a pain to get to, then also to get the side hose reattached (very little working space).
I have a brand new pump that is made for a Mercedes that I modified to work in our cars. PM me if interested.
hmm, i'll check it. i don't drive this car that much anymore and seems like it definitely likes to be driven rather than left dormant. also, it seems the lifespan of electrical items such as wiring is at the questionable point as i recently blew a fuse while using a compressor thru the cigarette lighter and now any replacement fuse i install blows immediately. of course i'm not complaining as long as the #2 bearings and turbo keep chugging.....(knock on wood!)
thanks for the help and i'll keep an eye on the pump.
also, fejjjj, what do you want for the pump?
or anyone else have one they're selling? what do these pumps even run? i don't remember seeing them for sale ever.
So, I was able to pull the plastic black cap on the top of the pump, ( note: remove it carefully. It has two plastic pins that snap into the body of the pump .. I used a single edge razor blade to get under the ears on the black plastic top, but went a little to far on one side ( SO be careful or you will cut the little pegs off ) When you get it off, use some Mobil One synthetic oil ( that's what I used, and it worked great ) just use a drop or two on the top of the bushing armature, and see how it just quiets down ..
I have to admit, I was pretty skeptical whether it was going to work, but it's been quite for 3 months so far
I also liked the fact that I didn't have to spend 220 bucks on a pump that is not a Porsche part
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Good luck
regards
Ed
When you get it off, use some Mobil One synthetic oil ( that's what I used, and it worked great ) just use a drop or two on the top of the bushing armature, and see how it just quiets down .. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I have to admit, I was pretty skeptical whether it was going to work, but it's been quite for 3 months so far![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Does anyone have any tips for swapping over the pump? Mines definately gone, its receiving 12v when i shut off the engine but its not spinning or makign any noise.
Do i need to part drain my coolant or has anyone found and easier way to do this?
I did mine when the car was apart ... I am thinking you can just pinch the hoses
