Is a 1990 3.0 944 block a candidate for a 3.0 turbo project?
Is a 1990 3.0L block from a 944 S2 a good starting point for a 3.0L turbo project for my 86 951? I have about two more years overseas until I move back to the U.S., and figured I could finish up a 3.0L long block while I'm here and ship it back with my household goods.
Background: I saw something that interested me on Spain's version of Craigslist, and it's in my area. http://www.segundamano.es/guadalajar...a=0_s&st=a&c=4 It definitely will not sell for its asking price of 1100 euro, and I'm wondering if I could snag this as a worthwhile parts car and what I should pay to make it worthwhile. Parts would have to be sold on eBay to the european market. Body has been modified (seems to have custom rear fender flares and some crazy front end work), and the front is now damaged. At one time, this was a car that someone put a lot of work into, but I don't have any details on it yet. I'm thinking about driving over to check it out myself, only 45-50 minutes away.
... only the car in the ad is not a 944S2 but rather a 924 with modified fenders.
From what I've seen on Rennlist, 944S2 engine conversions to Turbo have had mixed success. A fellow named Mike in Australia converted his S2 cab and the engine failed only a few months after. Something to do with the pistons IIRC.
S2 block is good for a 3 liter turbo in my book. Certainly better than starting with a 2.5 block, and aren't all 3 liter turbo efforts subject to mixed results?
I still don't know what it really is, been waiting for the callback. The ad is a bit inconsistent, but from my experience with the segundamano.es listing process, the user definitely had to select a model year of 1990. They may have only done that because they tried to make it look like a 1990. 'What if' they went as far as installing a motor from a 1990, or any other good bits that might have been done. Especially if they also transplanted the transaxle. As messed up as it looks, and considering somebody put a lot of effort into it at one time (those rear flares actually look really well done from the pics), my thinking is that this will go cheap, but there could be a few worthwhile gems in this car to keep and to make it worth parting the rest.
With regard to the other failure with turbocharging a 3.0L - yes, unless Mike installed low compression pistons, it would not have been a success. A non-turbo 944 motor has compression from the high 9's to the low 10's (depending on year, and the later years had 10.2:1), but the turbocharged version should be around 8.5:1. Based on what little I know at this point, my basic plan is to get a 3.0L block & crank, a 2.7 8V head (so I can reuse my stock intake and aftermarket headers) and only invest serious money in the pistons, rods, and turbocharger. I do not intend to create a beast, just a reliable motor in the 350hp range. My 2.5L with over 150k miles is tired and smoky - still trackable, still taken on trips as long as 3 hrs, and otherwise running just fine and with good AFR's, but I have a magnetic oil drain plug that's previously shown me some bad things. At the minimum it will need the typical rod bearing replacement, and then I might as well reseal it all, I have to replace the flywheel due to a broken tooth, etc. etc. I'm sure the work will add up quite a bit, and I just don't want to put all that work into a 2.5L - and not have an engine in the car for several weeks or months - if I can alternatively approach it as an upgrade to a 2.7L or 3.0L. I'm inspired in part by Sid's build/approach, and am trying to see if I can really do this successfully with a low-budget approach.
descripción
porche 924 con imagen de 944 para restaurar o piezas se pede sacar documentacio o se cambia por algo que me interesa
i dont know spanish, but that sounds like they made 924 look like 944..
I strongly suspect any problems experienced are unrelated to the choice of block, but rather the same issues at risk for any rebuild -- getting the piston to wall clearance right, getting the rings to seat, piston/rod materials, getting the compression and piston height right, etc.
Like the ad says, it's a 924 with bodywork.
Reason for the 1990 model year is that it was probably brought in from another EU country and first registered in Spain in 1990.
Good luck with your project and enjoy Madrid.
Professional Hoon
I could tell it was a 924 with out reading the description. What make me tell is a few things.
The flares.. On a 944 they are higher to the fuel filler cap. and the cap is flat on a 924 while on a 944 the cap is bent at the bottom.
The front end is a modified 924 front. nothing like a 944 S2
My memory of Mike in Australia's motor was that he ran stock or close to it, compression. Maybe Sean remembers, but I think he kept raising the boost up little by little and perhaps holed a piston. Seems like a long time ago.
