Running WAAAYYYYYY Rich. Where do I start?
#31
Was able to source what appear to have been a decent set of used injectors and got them installed yesterday. Along with that I was able to re-install the ICV mount with new Lord Mounts, a new FPR and a new (used) J Boot.
What makes the most sense to me is to send in the old injectors for servicing/matching. Assuming all are still serviceable (which as they are working at least to some degree, I would think would be the case) I will get them cleaned, serviced and matched. That should be as close as possible to a new set of stock injectors without the $$$$ price (Wow, what an expensive part!)
Car started fine and seems to be running just fine. Of course I will not really know that until I take a trip to the CA Smog.
Finally it was almost scary to handle the wiring. Clearly I need to order the wiring harnesses from LR and replace ASAP. There were a couple of times I thought I had broken wires.
And I'm getting much better at pulling and re-installing the intake manifold! As they say, kindergarten got easier for me each year!! :-)
#32
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Call me before you attempt installing the LR harnesses. I can save you some time and cursing. Overall, they are a very nice package, but certain instructions leave a lot to be desired. I installed all of them about six weeks ago.
