Gear linkage (gearbox side)
Professional Hoon
Does anyone make these? aftermarket ones?
This is what happened
The yellow part.. The circlip has came off and now i can't change gears except 1st & 3rd
Does anyone make aftermarket ones so that doesn't happen. Mine is a little sloppy over there too.
Get a complete set at only944.. They have a complete set which is also a short-shift kit! Only 89$, and no, i do not know them and i don't have the kit (yet) but i do read a lot of good things about it!
Do you want to repair the original or replace with a new design ?. a fix would be a washer instead of the circlip with a weld or maybe JB weld to retain it. I used a shark motorsport linkage which is what D9 sell I think.
