951 Engine Value
ISV has been replaced several times and found the wires were touching at the pigtail. I fixed the harness in that location and tried a new ISV and same issue. Another lister mentioned the resistors on the DME will burn out if the wires touch on the harness so I am trying that next and inspecting the solder joints.
This is reading my wideband, not on a dyno dont have the money to confirm... The wideband is new so I'm sure its fairly accurate
FIt would be quicker, figure its cheaper to take apart and fix but also if I have other issues in the DME it would make it harder to diagnose using mine. I'll consider that method after I solder in the new transistors
