new / replacement O2 sensor -- pro tip
new, oem ones go for between $140 and $200 (pelican parts, 944online, porsche dealer prices).
then i did a little homework and found out that it's a universal bosch 3 wire.
http://www.the944.com/oxygen.htm
they mention paragon had a kit, so, i checked them out and found this for $60:
https://www.paragon-products.com/3-w...osch_15726.htm
then, on a whim i did a quick search on the bosch OEM short part number and found what i ended up buying for $80:
yeah, i paid $20 more than the one from paragon, but no splicing required!
hopefully this helps anyone else needing to replace the O2 sensor... i'm really happy i saved 50% of what i initially thought i'd have to pay.
rockauto.com
just installed the Beck/Arnley OE type replacement
DELPHI Part # ES10762 Conductor Number: 3; Universal; Lambda Sensor: Heated; Length [mm]: 200
* Stocked in outlying warehouse--shipping delayed up to 3 business days
$39.89
BECK/ARNLEY Part # 1563091
W/Fed. Emis. [Wholesaler Closeout -- 30 Day Warranty] (Only 6 Remaining)
$57.79
BECK/ARNLEY Part # 1563093
W/Calif. Emis. [Wholesaler Closeout -- 30 Day Warranty]
$59.79
APWI Part # AP332
Non-Calif. ESV; Upstream; Engine VIN A
$61.89
DENSO Part # 2343030 {#2343020} OE Style
UPSTREAM
$78.79
NTK Part # 25516 NTK OE Type
Base Model; Upstream; 1
Turbo; Upstream; 1; 3 (Only 1 Remaining)
$78.79
APWI Part # AP350
Calif. ESV; Upstream; Engine VIN B (Only 2 Remaining)
$81.79
DELPHI Part # ES10241
Upstream; Wrench Size: 7/8 in.
* Stocked in outlying warehouse--shipping delayed up to 2 business days
$102.79
BOSCH Part # 13012 OE Type - Exact Fit; Heated; Wires: 3; Length (in): 25.2
w/ California Emissions; Upstream
Except California Emissions; Upstream
$103.99
STANDARD MOTOR PRODUCTS Part # SG68 {#95160313500, 95160613500}
UPSTREAM
$115.79
ACDELCO Part # 2131259 {Click Info Link for Alternate/OEM Part Numbers} 3 WIRE
SENSOR,HTD OXY(POSN 1) UPSTREAM; Engine VIN A
* Stocked in outlying warehouse--shipping delayed up to 5 business days
$119.79
$39.89
$57.79
$59.79
APWI Part # AP332
$61.89
UPSTREAM
$78.79
$78.79
APWI Part # AP350
$81.79
$102.79
$103.99
UPSTREAM
$115.79
$119.79
The only thing you have to worry about now when buying random things on Amazon that aren't fulfilled by Amazon is that you may get a Chinese knock-off part. Not saying that's what this is, but Amazon is basically AlibabaExpress at this point.
once i get it i'll report back w/my thoughts and some pics.
