86 turbo street/track suspension
Thanks for all the advice. I was looking at the Koni full coilover kit front and back for $1400 but another guy said the Koni shocks won't last long and I should go with blisten. The blistens are $600 more. But if they are that good then I'll bite the bullet and go for it. I hate when I sting and buy the cheaper stuff and then wish I spent a bit more. So if I wanna do full coils and delete the torsions, what spring rates u recommend front and rear for a street semi track setup? Also if my car has sways is it worth getting bigger ones?
If it were me, and I was doing it again. I would hang on to the $1400... Buy the KW Variant's for the 944, install w/ torsion bars and be done.
I have 440#/in up front, rear is 175#/in coilover + stock t-bar, per the recommendation of Ground Control. They made that recommendation based on (extensive?) testing, not just theoretical calculations. It's always worked very well for me. Setup includes a 26.8mm sway bar up front, 19mm 5-way adjustable sway bar in the rear. I can adjust the rear sway bar to make it loose or just barely tight, so I'm almost perfectly balanced. I could probably increase the front sway bar diameter and gain a little more balance.
At the spring rate you have, you should be able to completely remove your T-bars without changing the coilover springs. Your 350# springs have a higher effective rate on the rears because the mounting point on the trailing arm is forward of the wheel.
