proper direction to install front wheel bearing seal?
found the answer but to others reading this down the road wondering whats correct
http://im1.shutterfly.com/media/47a3...D550/ry%3D400/
this should be facing out
meaning you should be able to read part number when installed in spindal
Sometimes the Seal wears a slight groove in the Spindle, thousandth or two is not bad, deeper might bring on a leak/premature wear though. Seen JB Weld, Metal Magic ect used for the build-up, but a Weld build-up and machining will last another 25 years. Just saying they don't give those 'S' spindle's away, so take care of what you have.
