Trouble with Lindsey Racing oil baffle kit
Has anyone else had this issue?
Had the oil baffle welded in the pan. No issues there. Also had the ring welded onto the pick up tube, but there is an issue with the ring that goes around the oil pick up. No matter how I try to fit it, the pan will not clear the pick up tube with the Lindsey Racing Oil Baffle ring in place. Any ideas? Do you need to trim the internal plastic oil baffle? Hope not....
