best turbo for racing
Old 05-19-2013, 12:14 PM
dizzyj
dizzyj's Avatar
trying to think of everything related to engine:
balance shaft deletes
oringed head
carrio rods
manual boost controller
k27/8 turbo newly rebuilt.
3" exhaust
ok, i dont need 2k for sure. but not kicking in till 4 is a bit much. I've never had the car dyno'ed.
Does it matter if a turbo is put into a t40e housing? I'd like a direct bolt up, since i already have the LR 2 piece crossover pipe.
Can anyone quantify how much better something like that woudl be over a k27/8? again, its a bunch of coin. if it spools 100rpm earlier, then i wouldnt do it.
Old 05-19-2013, 12:21 PM
dizzyj
dizzyj's Avatar
Originally Posted by Rogue_Ant
No! That will be waayyy too much change.
Pickup an offset cam-key or fully adjustable cam-gear. Dial in 4-5° advance. And see if you like the results..
gotcha. glad i asked
Old 05-19-2013, 02:35 PM
mtnman82
mtnman82's Avatar
FYI, I have a K27/6 and it reaches 15 psi at ~3100 rpm. It starts boosting about 1000 rpm sooner. There was a recent thread where people claimed the K27/8 spooled nearly as fast as the /6. Sure sounds like there's a leak or something going on if you're not getting full boost until 4K. If you can't find any vacuum leaks, I'd probably look at the crossover for leaks or blockage, or make sure your wastegate is up to snuff.
Old 05-19-2013, 10:14 PM
eman930
eman930's Avatar
Yea something's wrong, I have a 26/8 and it hits 16psi at about 3000-3200rpm, that's with a 3" exhaust, stock DP, stock AFM, LR dual port, MBC, Late NA camshaft 4 degrees advanced.
Old 05-20-2013, 12:36 AM
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
that looks like the car from an old shop in va that I had spent alot of time does it have delete balancing shafts? If so and im sure it is cause the logos or one of it had a solid 350 hp. have you changed anything on the car since it left va? and it was racing in the GTU2 class in va.
Old 05-20-2013, 12:59 AM
dizzyj
dizzyj's Avatar
Ya that's the car. Bought it almost 2 years ago from va
Since then:
Gutted it
Rebuilt turbo (was shot)
New intercooler (was split)
Mtune
New mbc
Camnber plates
New clutch
New gauges
3 pc crossmember
2 pc crossover pipe
Countless bolts/bushings/etc
I'm racing it in pca gt3. It's definitely gettin loved
Old 05-20-2013, 02:05 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Check the crossover for leaks.
It makes a massive amount of differences.
Old 05-20-2013, 12:48 PM
fast951
fast951's Avatar
A K27/8 should hit boost (in 4th gear) much sooner than 4000RPM. Check for exhaust leaks and revisit yor boost control.
The X-over pipe is double walls, I have seen the interior wall collapse restricting flow and slowing down the turbo. There is no way to tell if the inner wall collapsed, except to look on the inside. Or check back pressure at test port in the "Y" fo the X-over, then at O2 sensor, then after the turbo. The differential in back pressure will give you an indication of the integrity of the inner wall.
John
Email
www.vitesseracing.com
Old 05-20-2013, 07:45 PM
951_RS
951_RS's Avatar
I definitely agree with the recommendations to check your x-over pipe.
When my x-over pipe was leaking my spool time suffered greatly (to4e 50 trim - spooling at ~4k)
Once fixed it made a considerable difference.
Old 05-20-2013, 10:05 PM
dizzyj
dizzyj's Avatar
ok, so what I'm hearing is fix my sh*t and keep the k27/8? im fine with that. much cheaper
Old 05-20-2013, 10:39 PM
333pg333
333pg333's Avatar
https://rennlist.com/forums/944-turb...-worth-it.html
Going off the description that this guy is having with his turbo you should be experiencing better response.
Old 05-21-2013, 05:22 AM
Paulyy
Professional Hoon
Paulyy's Avatar
I don't think he has a 'normal' k27 compressor
Old 11-20-2013, 01:20 AM
dizzyj
dizzyj's Avatar
bump for an oldish thread
6 months (and a new baby) later and I have rebuilt my engine. I definitely had some major exhaust leakage at the turbo hot side due to bolts backing out. I also had some major compression issues due to an extremely dirty head.
I had the head rebuilt (and ported and polished, cause hey, why not?) and replaced all the bearings at the same time. Only thing I did not do was new rings. I replaced everything with nord lock washers so hopefully the hot side wont back off again.
I also added an o2 sensor. The car had a a wbo2 in place of the nb02 spot with it run in open loop. I added a new location for the wb02.
She is spooling quite a bit faster now. hoping to get on a dyno soon to see some actual data vs the butt dyno.
Quick Reply: best turbo for racing
