Coolant issue after shutdown
Try driving a long way but without any boost -- fully warm it up over 20 - 30 miles or so -- then see if it spits up. If no overflow that way, then go out again and drive it hard on boost and see if it then spits up. If it only overflows after boosting, start saving for head gaskets...
Going with the pack
is quite monotonous.
Nothing like a problem that ranges from a $15 cap to a new engine.
So you could also have air in the system from when you refilled it if it was not bled properly. Also according to Lindsey Racing, the heads have poor cooling on cylinder 4 which may be overheating?
Try popping the cap off and smelling the coolant. If it is a head sealing issue, it generally means the head is lifting and you're leaking combustion pressure into the cooling system...I have experienced this, and the coolant will smell terrible if that's the problem.
Odds are pretty good that it's just the cap or maybe even an air pocket, but it could definitely be something more sinister.
Good point on smelling the Coolant, Part House's have a chemical that can test for exhaust Gases in the Coolant which could save you some hopefully unnecessary worry and work.
WRONGLY ACCUSED!
Received 4,056 Likes
WRONGLY ACCUSED!
New cap installed and I took it for a spirited run in 85 degree heat. No coolant issue - cap did the trick! Thanks for all the input. Didn't really want to do a head gasket.
