Rogue Logger/Tuner Discussion
#61
bringing an old thread back. Has anyone seen it where the logged AFR is incorrect, My gauge in the car reads one thing, and the logger reads about a point or 2 off from the gauge, I have the correct innovative file loaded. Just seeing if anyones had the issue and what did they do.
#62
#63
Yeah Its the ADX setup file, Ive checked and double checked all grounds and wiring to the logger, unfortunately Josh's files are password protected and cant be edited.
#64
I didn't really trust mine. Never validated but recall trying to reset the innovate WB02 several times to see if it would make a difference in the readings. I had the car tuned and had the dyno which showed the AF ratio and couldn't seem to duplicate those numbers on the logger. Everything else with the logger was fine. I was going to try a different sensor but never did.
#65
I'd call Lindsey racing and see if you can get the PW. I don't see why it's PW protected anyhow. I think the only difference from one adx file to the next is the voltage conversation from your specific wbo2.
#66
I have the same issue with my MTX-L and DME Logger. I reprogrammed the O2 sensor output voltage curve so it more closely matches what the digital gauge is displaying. I have a host of other issues with the DME Logger so I don't use it that much anymore.
Yes PW to the .adx file would be nice though.
#67
hmm at least I'm not the only one
