Rogue Logger/Tuner Discussion
#31
Yep, been running mine for ~2 weeks now and I'm really digging it. Still working thru a possible minor data issue with Joshua but everything looks great. I also still need to get a wideband installed (I know, I know...).
So being a total newb to this software, can you guys clue me in how to review the raw data in a list (i.e. import it to excel)?
Also wondering if anyone else is running the logger with A-tune, stock injectors? I'd like to compare notes if there is...
Oh, and I'd also be very interested in being able to mark places in the log file for the same reason as Omni.
#32
#33
thanks Jim - I'll play around some...
#34
Professional Hoon
What i do with my LM-2 is when im recording, and i notice something is up, i look at the screen and it has a time it's been logging for, remember the number and i write it down asap in my notepad.
I haven't played with joshes logger but somewhere should have the amount of time it's been logging.
#35
I'm gonna try and get mine running this weekend. I've got the logger wiring from Josh, but can anyone tell me how to wire up the Wideband? All that the website says is "*A separate WBO2 controller and sensor is required, with a 0-5volt output, which needs to be fed to the DME for logging ability."
I have the lines from my controller but where do they go?
#36
#38
No other mod's to the DME - just wire in to pin 30?
#39
Small Business Partner
Zeff,
Email replied.
FYI - different WBO2 controllers output a different 0-5volt value for a given AFR. So, we have a few logger configuration file options for the popular WBO2 controllers.
Email replied.
#41
I have my tuner installed and running. It seems to work really well so far. My idle was low in general and in particular when the AC kicks in so I adjusted it and uploaded the tune and it seemed to fix the problem. I am now looking to install the logger - SUPER DUMB QUESTION - where should I run the ground wire? I just don't want to screw it up - maybe it can go with any other ground? Do I need to add a terminal to the wire to do it properly?
Also, I have a PLX wideband, do you think I will be able to just run a wire off the control box? I haven't looked at the control box yet but should this be pretty simple?
#45
