Spec Clutch - Stage 3+ review
Professional Hoon
I want to do a review on the Spec Stage 3+ clutch as there's a lot of people who don't like spec clutches and theres people who like it.
Please note this isn't a Stage 3 but it's a Stage 3+ (note the +)
The difference is the Stage 3 is either a 3 or 6 puck, where the Stage 3+ is a full face disc.
The Review:
I wanted a clutch that can handle higher amounts of torque with no slip. i wanted at least handle 550 ft/lb (flywheel). I also wanted the pedel to be near stock feel with the engagement. I didn't want it to be harder to press as i drive it every day.
After a lot of time searching and questioning, I came up with the Spec Stage 3+ clutch. I had a few people try steer me away from it, but i'm not sure if they know the difference with the + or not.
The clutch disc is a full face carbon semi metallic disc.
The pressure plate is a Sachs PP. I have a semi aluminium one which means the internals are aluminium, not steel which is lighter.
First thoughts
I didn't really like it, but i gave it a chance thought break in. The engagement was the same, but there's a smaller amount of time where its engaged to disengaged. And it was as soon as you put pressure on the peddle it was disengaging already. That took a small amount of driving to get use to.
The shatter was bad, I didn't like it.. It was annoying but i gave it a chance.
After break-in
After i broke it in with city driving, and just driving. I love it, Shatter free! smooth like stock, maybe a little harsher if you let go of the peddle quick, it'll just lock. In reverse it'll shatter a little (not sure why) but it's very minimal. Mind you my driveway is on a slant and i need to ride the clutch to get in it and no chatter.
It actually is a really good clutch.
The Review:
First thoughts
After break-in
I don't know, but I think there are so many friction materials and variations available that no two people are necessarily talking about the same Spec disk. For me, I gave my spec disk almost 5k mile, and it only got worse. Chattered so bad it scortched the flywheel. Single worst thing I've ever installed on my car...
Professional Hoon
Basically the Stage 3+ is referring to the clutch disc and not the PP
Glad to hear it work out for you Pauly.
I'm liking my spec setup. No issues with my setup either.
I've driven far worse clutch setups before in other vehicles.....and they were stock clutches. Ever driven a lifted 75 Ford 4x4 with a 360 4 speed
The worst clutches on our car will never compare to that.
Professional Hoon
Don't have them in Australia ahah!
I have this feeling, most people who get the spec clutches either get the 3/6 puck clutch or get the full face metallic clutch not knowing the material differences. Which is either a stage 3 or stage 3 with that disc is had a constant chatter. I think that's the issue on why people don't like them.
I ran the Spec Stage 3 Hybrid clutch on my stroker and really liked it. Only had about 1000 miles on it however. I am using it on my new motor also so time should tell.
I am not a big spec fan. My clutch assembly was sent back to Spec to be evaluated for a vibration, disengagement issues and chatter. They said it must be another issue because the clutch assembly check out fine. I chased my tail trying to fix the issues and almost bought another transaxle.
All the issues resolved after installing a LS7 clutch. I sent the Spec out to a local machine shop who said it was out of balance. Spec won't take any responsibility. They blamed the installation. Installing a clutch is not a black art.
I currently have the full faced metallic stage 3 and I like it. Exactly like Paulyy explained.
I ran the stage 3 hybrid before but it started to slip on me. This only happened at the track though with good traction. Never had a problem on the street.
A number of years ago I installed a SACHS sports race clutch and loved it... however, I never ran wild power back in those days so I am not sure how much power / tq it could handle. Does anyone know what the Sachs sports race clutch with aluminum flywheel will handle?
I need to replace my clutch soon (its currently stock and its warn) as I am starting my project build and targeting 450hp so want something as close to stock feel but can handle the power.
Originally I was thinking Spec 3 but I am not sure I like the sounds of how it engages as 90% of my driving will be on the road and in traffic. Thoughts and suggestions?
With the spec there are quite a few different combos you can go with.
Pauly we should compile a combination chart for everyones spec setup. It appears that there are some combos that work better than others as far as comfort and performance etc.
