Rebuilding M030 front shocks
This is truechoice.
Were the M030 rears the same as the Sport rears? I thought the valving was different. The rears are $180 each and fronts are $210 each
Paragon has a 20% off sale on Koni products right now. As was said before, it's more economical to just buy new rears unless you want to convert yours to a different rate or DA.
http://www.paragon-products.com/Koni...8040-1035s.htm
On a related note, I will be swapping our the torsion bars. What bushing should I replace while doing so? I see all kinds of track oriented choices for the rear but this is mainly a street car and I don't want noisy bushings.
They tend to hold up pretty well. I have not seen any of the rear bushings that are destroyed, but Im sure it does happen. Certainly the rear suspension bushings hold up much better than the front swaybar bushings for example.
The rear carrier flange bushings should be fine, since there is no rotation in that joint. Check the inner trailing arm bushings, and the spring plate bushings. But there is a good chance they will be ok.
Elephant Racing makes replacement rubber spring plate bushings. Other than that there are the torsion tube carrier mounts that Porsche sells replacements for a reasonable price.
When you send out the M030 front struts, do you send them out with the springs for more accurate valving? Or just the struts?
And I see two KONI rebuild centers, one in Cali, one in Ohio. Which one would you recommend?
They will usually charge extra to remove the springs. If you are having them rebuilt stock, no need, they will reuse the existing valving. If you want them custom valved for a different spring rate, then you can tell them corner weights and intended spring rates and they can setup the valving for that application.
Used to have Koni North America rebuild in KY, but they have since outsourced the service to a couple authorized vendors. TrueChoice in OH and Performance Shock in CA. But I think TrueChoice is gone or bought out. Looks like Performance Shock has a shop in OH now, so maybe they bought TrueChoice. Koni website now lists another shop Pro Parts in AZ a a service center (in addition to Performance Shock), but I've never heard of them.
All they said was that all the internals needed to be replaced with updated stuff. The original estimate was $600.
Painted was $200. That's a bit much actually for my taste. They would have just sandblasted for $25 each shock. In a previous life I was a painter/finisher. They told me they use automotive paint so I figured I'd check the price of automotive paint. It was about $200 so I said go ahead and do it. But when the shocks arrived, don't laugh, I smelled that is was really just rattle can paint.
Mike G.
