Upper balance shaft cover without sealant?
Just removed upper balance shaft cover to fix leaky end oring. Funny thing is that cover just fell off - there was no loctite used at all - mating surfaces are perfectly clean. Is this normal? Car is 88 Turbo S and cover itself was not leaking at all? Do the cars with integrated bearing bridge do not use sealant due to it's thickness - I believe that it always adds some microns and enlarge gap between shaft and bearing?
Mine looked the same way ( LBS cover, like there was nothing on it ) and it didn't leak
Loctite 574 .... is to be used ( If you read up on how this stuff works its pretty amazing ... )
