Afr's what should I see
Hey guys finally got my wideband installed and i was wondering what air/fuel ratios i should see at cold idle, warm idle, normal acceleration and WOT?
Cold idle will be a little rich, warm idle should dither right around 14.7, normal acceleration will vary based on load/RPM. WOT should be in the mid to high 11s.
Ideal full-load AFR is considered to be around 11.7. At the track I'll see 11.3 when pushed hard. Idle cold will be around 12.5-13.5; normal operating temp will be around 14.7 (stoich); a hot car will get up as high as 16.
Yes.
Cyclone, your cold idle definitely seems much too rich. You're sure the WB has had time to warm up? They typically won't read properly for a minute or so, until they warm up.
Small Business Partner
The cold-start will be rich, especially depending on the outside temperature.
Basic Sponsor
that's right but if you running above 18 psi is 11:3-11:7 max, if iam not mistaken right Josh?
Hey Josh would a bad ISV cause it to be a little richer? I usually have to give some throttle when cranking to get it to idle at first and the ARF's stay in the low 10's until it warms a bit (3min) then it goes to mid 10.5-10.9 and full warm is in the 14.5 range.
I run 17psi and it holds till redline in atleast the first 3 gears, hardly ever use fourth. I'm trying to get some stuff under control before I get her on the dyno. I emptied my aftermarket catch can today (it's line between AOS and MAF Tree), no oil came out only clear water (condensation).
I bought my tps and isv from work I'm defecting them out this week and getting new ones. That extra oil from my turbo I know made my tps act up. I put a restrictor in and now it seems way better, just giving a few days for some of the oil to clear out of the intake.
