Engine reseal - missing anything?
Trying to collect a list of parts/gaskets/etc. that I need to reseal my engine while it's out of the car. Might do a head rebuild too, but I didn't include those parts.
What I already have/have done:
-Rod bearings
-waterpump and gasket
-oil cooler/housing gasket set
-dipstick seal
-balance shaft flange gaskets
-balance shaft front o-rings
-balance shaft rear seal
-front camshaft seal
-cam o-ring seal
-AOS upper and lower seals
-oil cap seal
-copper exhaust gaskets
What I know I need:
-oil pan gasket (have one with hardly any time on it, but might get another one just in case)
-head gasket (same as the oil pan, have a widefire and might reuse)
-cam tower paper gasket
-rear cam tower gasket
-intake gaskets
-oil pickup seal
-front and rear main
-power steering rebuild kit
-water neck gasket top/bottom
-rear coolant port gasket
-turbo o-rings
-oil return seal
Am I missing anything?
-Rod bearings
-dipstick seal
-cam o-ring seal
-oil cap seal
What I know I need:
-intake gaskets
-oil pickup seal
-turbo o-rings
-oil return seal
exhaust manifold gaskets (X4). Yes, I would check seal kit prices against buying individually. I used Paragon and I bought a kit minus HG (as I used a Cometic).
Speaking of the oil return seal. I'm in the process of completing rod bearing job and have the oil return tube seal, but don't really see a groove for it. Both surfaces look to be flat. Any suggestions?
I'll have to take a look at mine, I don't quite remember from when I pulled it apart.
Found a good list here in case anyone else wants a reference:
http://reutterwerk.com/forums/showthread.php?p=85063
I'll also be making up a spreadsheet with prices for future reference.
https://dl.dropbox.com/u/57372766/951.xlsx
