Cracked headers?
This is what I discovered after removing headers - looks like hair size cracks. Is this acceptable or I should give them for re-welding? I would weld them anyway but local shop that deals with stainless welding is damn expensive... What to do?
Did you water test them ? The reason I ask is that's a little difficult to see ..
If they are cracked you are lucky they are cracked there ... Most times they crack at the branch points and it seems most say its tough to fix.. ( both to weld and stay fixed and to remove the HS )Those look a lot easier to fix because they are at the end and you don't have to remove the heat shielding
regards
Ed
regards
Ed
Since they were off I had mine welded up around the flanges and at the Y's...then had them coated. We cut the heat shields off to get in there and since I had them coated didn't see the need to try attaching them again (which would have been a bitch).
Hope this helps.
Hope this helps.
( you know, how you test a leak in a inner tube tire? ) ... Regardless the easiest fix is to have them welded around the flanges... As Racerxrick said if you have a crack at the Y then you have to remove the HS to make the repair
