New Knock Counter
Old 02-03-2013, 06:25 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Default New Knock Counter
Been working on an enhanced knock counter. In addition to counting all knocks like a Curtis counter, it also keeps a separate knock count for wide open throttle knocking (i.e., counts happening when the full throttle signal --KLR pin 18 -- is active). It also creates a fixed pulse for the Zeitronix to log for each knock event. Haven't finished all the software yet, but the possibilities are endless with the Arduino. Planning to keep track of knock by rpm so I can scroll through and see where the knock is happening. Also planning to integrate with my boost controller to pull boost and/or with the Vitesse piggback to switch to a safety map or to trigger the V-Flex protection mode if too much knock happens...
Old 02-03-2013, 06:32 PM
Fluidplay
Fluidplay's Avatar
That's cool Tom, can you re-set to zero?
Black51
Black51's Avatar
So the question is, how much knock is too much knock?
Old 02-03-2013, 06:54 PM
refresh951
refresh951's Avatar
Nice project Tom! Are you going to post schematics?
Old 02-03-2013, 08:04 PM
F18Rep
F18Rep's Avatar
Cool...B
Old 02-04-2013, 12:40 AM
Tom M'Guinn
I haven't actually written one up but can once I'm done. Right now, there is almost nothing but the arduino and the LCD. I made up a semi-clean power supply with a 7812 and several decoupling capacitors, and am running the knock and full throttle signals through (fast) voltage followers (CA3240EZ) to be on the safe side. The programming code is probably the more interesting part, but for now it's still work in process as I add in the functionality.
Sure, I could reset it to pi if I wanted. The whole thing is programmable, so resetting is no issue at all... (I added a reset switch to my Curtis counter a while back -- there was a thread showing how...)
I hope not to find out. If I'm getting consistent knocks at any rpm at WOT, I try to dial it out with less timing or boost. Otherwise, with healthy boost, I live with 1 or 2 random (non-recurring) WOT counts per gear... Wish I had a knock counter back when I was blowing head gaskets like crazy -- I'm guessing I would have seen a consistent and large number of counts per gear...
Old 02-04-2013, 01:14 AM
Crazy Eddie
Crazy Eddie's Avatar
I hope I can use one of those with the set up I have ...
Nice Shift boot
Old 02-04-2013, 01:31 AM
Tom M'Guinn
Nice Shift boot
You bet - it will be the first Element in the country with a knock counter...
Shift boot is a 10 yr old aftermarket replacement. I was looking for one made of limp maroon leather with less texture, like an old lady's hand bag, but what are ya gonna do...
Old 02-04-2013, 01:56 AM
333pg333
333pg333's Avatar
Great work as usual Tom. Should produce some interesting data.
ps...I thought your shift boot was Mr T's Ball sack!
Old 02-04-2013, 02:01 AM
Crazy Eddie
You are killing me
Old 02-04-2013, 02:02 AM
Crazy Eddie
Yea.... so did I
Old 02-04-2013, 11:19 AM
reno808
reno808's Avatar
Pretty cool. Why do you have 2 Zitronix Gauges? if they are multi guages
Old 02-04-2013, 11:46 AM
Tom M'Guinn
I got the first one before they came out with the multi. I installed them both because it's helpful to see more than one output at a time (boost v AFR, EGT v AFR, etc.).
Old 02-04-2013, 02:21 PM
reno808
reno808's Avatar
I see. BTW you know the Multi one can show 2 outputs at the same time.
Where are you going to place your counter?
Old 02-04-2013, 02:53 PM
pozican
pozican's Avatar
I may have missed it; how are you connecting the arduino to the KLR? Or is it through the zeitronix?
Quick Reply: New Knock Counter
