Rim width vs. tire width
I bought new (used) rims and I thought the rear widths were 10, but they are 11. I already have new 275s (Michelin PS2). Do I need wider tires or can I go with the 275s still?
TIA
TIA
Assuming your offset is okay, a 275 section width is too narrow for 11 in. wide rim, you'd end up with a stretched look- wouldn't look right on our cars imo. I'd go with 285 at the minimum if not 295s.
yeah, 275 will be a stretch. my rears are stretched so they will not rub too bad. I have 11.5" rears with a 285/30/18. here are a couple pictures.
Attachment 696880
Attachment 696881
Attachment 696880
Attachment 696881
Dillon - That's some seriously wide rims. Doesn't look all that bad actually but at least you've got 285s. With 11.5, 325/335 can be mounted on there- wouldn't that be bad *** if we could do that on turbo s stock fenders?
It's too bad you are in the west coast. I have a set of 295s you could try on- would fit 11 perfectly.
The offset is 45 with stock M030/ '89 turbo suspension. It's been lowered, too
Some have success fitting the 45 offset, though metal persuasion and more negative camber is a must. With a lowered suspension the 65 offset 10" wheel would be best. You could try the 993 and later wide body folks for a trade.
Here is my '89 with et63 11" rear wheels...
