Tilton Pedal sets mounting pictures needed.
Old 12-13-2013, 06:27 PM
theamsoilguy
theamsoilguy's Avatar
Im ready to order my tilton 600 series floor mount so I can get rid of the 'cobbled' together brake system and booster in my car. I have the lindsey #8 kit, big blacks and 996tt rotors. Any suggestions on bore sizes from the guys who have done this? PS: 700/900lb springs, turbo 86 rears, no proportion valve.
Old 12-13-2013, 11:38 PM
SoloRacer
SoloRacer's Avatar
Gotta say it, love the alcantara dash. Looks so clean and classy
Old 12-14-2013, 02:33 AM
xtaC
xtaC's Avatar
Thanks for posting those pics mate, it was exactly what I was looking for to mount mine; and its RHD as well!
Old 12-14-2013, 12:47 PM
PorscheDoc
PorscheDoc's Avatar
Where are you guys sourcing your tilton 600 setups from? I am thinking about ditching the firewall mount system and convert to the floor mount as well on the V8 car.
Old 12-15-2013, 04:08 AM
xtaC
xtaC's Avatar
I ordered mine through Summit, with a bunch of LS1 parts, for convenience.
Old 12-15-2013, 01:26 PM
rlets
rlets's Avatar
Here's my setup.
Tilton 600 setup with a 3/8" aluminum plate bolted to the floor and side sill and a custom dead pedal. Moves my seating position 4" rearward which works only because I'm 5' 7".
Rich
Old 12-15-2013, 06:23 PM
Dutch944
Dutch944's Avatar
Nice Rich! This looks like something that could work for me as well :-)
Old 12-15-2013, 07:33 PM
333pg333
333pg333's Avatar
+1 very nice fit out!
Old 12-15-2013, 09:04 PM
Techno Duck
Techno Duck's Avatar
Check out this thread also. A local friend of mine has a pretty slick setup with a Tilton 600 series clutch and brake assembly. The pedal is for the electronic throttle for the LS3 crate motor, so disregard that .
They detailed some of the install also, but from what i remember they modified the firewall a little so that it wouldn't push the seating position too far back.
http://944hybrids.forumotion.com/t22...ed-brake-pedal
Old 12-16-2013, 01:00 PM
PorscheDoc
PorscheDoc's Avatar
Are you guys running the compact tilton series 75 master cylinders or something else?
edit: I found the new series 76 from tilton now has a top AN port for the brake line, which would provide a bit of extra room vs having to attach the fitting to the back of the cylinder against the firewall. The lengths are the same as the series 75, so I think that is the way to go.
Old 12-16-2013, 04:49 PM
theamsoilguy
Still wondering about slave sizes, have the big black fronts from lindey and turbo rears. Clutch size also. I want to order my parts
Old 12-16-2013, 05:15 PM
PorscheDoc
PorscheDoc's Avatar
I want to say the clutch master stock size from memory is 3/4. I think the V8 guys move to a 7/8" IIRC.
Old 12-16-2013, 07:53 PM
rlets
rlets's Avatar
I run 3/4" front and 7/8" rear Wilwood compact masters. This with BigRed front and 944 turbo rear calipers. The clutch master is a 1" but that's with the v8 conversion.
Rich
Old 12-17-2013, 02:17 PM
theamsoilguy
Rich
Rich, thanks for that. Big Blacks are the same as Big Reds right? Im running 86 turbo rears and also a LS conversion. Are you running the factory proportioning valve with those bore sizes or it that removed from your system? Why do the V8 guys want a bigger clutch bore? I believe I have a factory clutch master now until I switch to the 600 pedals.
I know Lanny was at the track this year with a new pedal assembly and I should have asked the details about what he was running then.
Old 12-18-2013, 02:15 PM
rlets
rlets's Avatar
Yes, BigBlack and BigRed are the same piston sizes so we've got the same calipers. I ditched the hydraulic proportioning valve and use the balance bar on the pedal.
The clutch master was tricky for me. I started with a 13/16" like lots of the guys have used with the factory pedal but I couldn't get good clutch release. Changing up to the 1" made things work but the effort is pretty high.
Rich
Quick Reply: Tilton Pedal sets mounting pictures needed.
