Rogue Tuning
#46
But on his website you get only the note to send a quote request for his services. Thus I took the easier way and ordered Plug'n Play by Joshua.
meanwhile I came across another 944 supporter in UK
Our 944s are still alive.
#47
I've been thinking about the m tune for a little while now. Good to know josh is so trusted by everyone here. Will definitely order from him once my car is ready for it.
#48
It took a while to get my M-Tune and it never crossed my mind that he was going to take my money and run. If you never get your package it's because the postal service lost it. If that's the case the package should be insured and you will have to be patient and work things out.
#49
Joshua, I have to apologize. I can confirm that I received the shipping notice. Many thanks to you and all the best for your egineering degree and your finger as well.
BR Christian
BR Christian
#51
Please don't turn this thread into a Vitesse vs Rogue thread, it has already been discussed(search). It really boils down to personal preference.
#52
Didn't think so.
Just bugging you.
But seriously, anyone else excited about Rogue's new DME's?!
#54
Did he build a new DME from scratch like Rogue?... http://roguetuning.com/rogue_tuning_ecu
Didn't think so.
Didn't think so.
http://www.augmentautomotive.co.uk/augtronic\\.
#55
DME copies are available. This has been posted several times.
#56
As far as I can tell that is not a copy...it is a completely different ECU with there own software. Rogue Tuning's is a true copy in the fact that it is identical to the original except it's a modern day design. You can run any standard chip in his, even the original chip from the factory if you wanted.
#57
Well I was wrong about it being a copy. It's just backward compatible.
Good point about the IP (would it be Porsche or Bosch?). For clarification, this computer was designed and built from the ground up starting with a blank-slate. It is not a DME copy/replica. Rather is is a completely new, backwards compatible ECU. You do have a good point regarding the brand-name, and as such I will refer to this as an ECU, not a DME.
